CPU Fan Speed is 7000RPM?!
Commandermadi
330
So I just installed a brand new cooler master nepton 280L dual cooler on my CPU and eveything is completely calm inside my case even when the panels are off. However, in the BIOS and using HWMonitor and Speedfan, the CPU Fan is 7000 RPM. How is that even possible? Is it a bug or what?
I asked the guys at Cooler master and they said that 7000-7400 RPM is perfectly normal and is the optimal pump RPM and it should be unlike other fans running at 100% all time and my CPU_Fan header seem to be doing that on its own. So I guess I am good to go? What do you think?
Thanks for your answer but my BIOS is already upgraded to the latest version.
