Hello guys, I am trying to fix a PC from a friend and now after a couple of days I am tired of it. Got no solution for it..
PC has a FM2A68M-HD+ Motherboard and a AMD A8-7600 CPU.
He gave me his PC with an info that it probably overheats. And that is correct!
So I installed Speed Fan and wanted to check the Temperature, GPU Normal, CPU is little bit higher BUT FAN that is on CPU is running the whole time with a SAME SPEED!
I tried changing it in Speed Fan. So the Temperature is around 40-45 in Idle and goes to 65.
Fan is really silent, almost no sound from it, even when the temperature went to 65 speed was the same.
So I checked inside their AsRock Utility thingy and there are some options to change CPU Fan on Performance, Silent and no idea what, forgot already (if its needed I will check).
So pretty much the PC is working ok I would say, only the heating thing is a little problem..
Well I hope I will get some help from You guys!
!! I googled already for a solution, and I read something about putting in AsRock UEFI fan speed to automatic, but I do not have it there!
Thanks.
N
Thanks.
N
