CPU fan speed won't change
Alright I have a problem.
My CPU fan will not increase speed. I have it set to dynamic speed control in the BIOS. It used to properly speed up with CPU temp and slow back down. Now it just sits at 512rpm.
The weird part is that multiple programs confirm that the motherboard is telling the fan to speed up under load (increasing fan speed %), but nothing. The fan does not speed up.
I have flashed the BIOS already. Didn't help
I have tried 3 different PWM fans. All the same deal.
I recently changed between boards without reinstalling Windows. Both MSI z77 boards and I do not know if this happened after the swap. I believe that it only happened recently and was working since the swap.
Any ideas?
Sounds kind of like corrosion somewhere.
That board appears to have 4-pin system fan headers. Do they work correctly?
If you can't find the fault, it's possible that you could set it to ignore the lack of a CPU fan, and use one of the system headers, set to vary based on CPU temp.
I have used the motherboard company provided program to try to change the fan speed. I can change it all day, but the fan itself does not actually change speed.
I have used 1 Noctua, 1 Corsair, and 1 Enermax fan. All on the CPU_FAN header.
Board is an MSI Z77ma-G45. I have previously used this board and the fan control has functioned properly.
I thought so, but when you boot the PC the fan spins up to max speed, then down to where it just sits. I know the board will power the header properly.
Also, Even if I set it to run at 100% in the BIOS, and then reboot the PC and re-enter the BIOS, it still just spins at the same slow speed even though the BIOS says it should be at 100%
hmm.. Either Windows acting up or the mobo going to die... My solution to test windows, load up a Linux Live USB and try changing stuff from there... Although, I 99% of the time advocate Linux in almost any situation... The fact that you said that it spins up to full on boot makes me doubt it's windows as BIOS doesn't question the HDD for a boot during POST.. most likely motherboard
I had a similar problem and put an aftermarket Gigabyte fan speed controller on the box with a variable resistor on a volume knob on the front ... it goes to the fan on the watercooler radiator. When son no 4 games he turns the knob up ... when listening to music he turns it down. I had a similar problem with two different boards over the years. I realise this doesn't help you in the slightest ... my bad.
