I built a new gaming PC in July, specs are as follows:
Asus z270e MoBo
i7 7700k
Cryorig H7
16 Gb DDR4 ram
ASUS ROG Strix GTX 1080
Corsair 750w PSU
500GB SSD
1TB HDD
My CPU cooler is connected to the 4 pin CPU_FAN header, my chassis fans are connected to the CHA_FAN headers
For some reason my CPU fan is running rather eratically. Every now and then, even when completely idle, the fan will rev up to full speed for literally 1 second and then slow down again. I've checked temps and CPU usage when this happens but nothing changes, the fan just seems to speed up for no reason. For example, I left my PC on overnight, at around 6am, it revved up loud enough to wake me up, then stopped almost instantly.
I calibrated the fans in the BIOS with Q-fan control, set it to PWM and when idle it runs between 300-400 rpm but every so often it will shoot up to 1500-2000 with no apparent reason.
Previously I had the NZXT Kraken x52 installed and had the same issues, but I swapped it out thinking it might have been a fault with the cooler, but the issue still happens with my new air cooler.
Would anyone have any ideas what could be the issue?
Thanks a lot,
Jessica
Asus z270e MoBo
i7 7700k
Cryorig H7
16 Gb DDR4 ram
Corsair 750w PSU
500GB SSD
1TB HDD
Thanks a lot,
Jessica
