CPU fan spinning backwards?
Jonathan Sifleet
926
Hey, my CPU fan is spinning backwards, and I have no idea why, is there any way I can fix this?
Sorry about bad quality and the sound (I was listening to Hadouken):
[flash=320,240]http://www.youtube.com/v/77FvhMjv2uM&feature=youtu.be[/flash]
I don't care that its blowing, I just want to know why it's turning backwards. If I wanted it to blow I'd mount it the other way round.
it literally cant blow it away with the fan orientation like on the video and if it spins anti clockwise. you probably feel the air that already went thrugh the cooler and was bounced back by the mb or whatever.
It is very little air movement. Although the main problem still isn't solved. How can I get it to spin the other way. I know I'm answering my own question, but I don't think it can I think that's the way the motor was designed. But I'm getting reasonable temps (49 degrees with 93% CPU usage).
