CPU Fan Splitter
kevinxia159
53
I have a Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard and im looking to add 3 chassis fans. Im looking to get 3 of these fans http://www.newegg.com/Product/Product.aspx?Item=9SIA68V21E0546&ignorebbr=1. 2 for the front and 1 for the rear. I have the NZXT s210 case. Can someone find me a chassis fan splitter that will support both my motherboard and fans?
These fans appear to be 3-pin, voltage-controlled fans.
Your CASE_FAN headers needs to be either 3-pin or 4-pin with backwards compatibility (3-pin will work, but 4-pin from mobo is uncertain).
*I would actually just connect them with the 4-pin MOLEX and run at a constant speed using the 7V adapter.
(should be plenty of cooling, and quiet enough not to benefit from fan control dropping lower)
Otherwise, it looks like what you're asking about is a 3-pin fan splitter. Might as well get 4-pin as it's backwards compatible:
https://www.amazon.com/SilverStone-Technology-Sleeved-Splitter-CPF01/dp/B00B46XKKQ/ref=sr_1_1?s=pc&ie=UTF8&qid=1467610262&sr=1-1&keywords=fan+splitter
I could be wrong, but do you only have ONE fan header aside from the CPU's?
According to the mobo manual, I only have one fan header. The case came with a rear fan so I think I can use that connecter for the rear fan.
Latest posts
