musango70
Hi there i am having problems starting my computer. The power supply and mother board fan will turn for about 30secs then stop and computer will not start.
Work systematically through our standard checklist and troubleshooting thread:
http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
I mean work through, not just read over it. We spent a lot of time on this. It should find most of the problems.
If not, continue.
The following is an expansion of my troubleshooting tips in the breadboarding link in the "Cannot boot" thread.
I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
Breadboard - that will help isolate any kind of case problem you might have.
http://www.tomshardware.com/forum/262730-31-breadboarding
Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
Make sure you plug the CPU power cable in. The system will not boot without it.
I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
If no beeps:
Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
http://www.youtube.com/watch?v=5FWXgQSokF4&feature=youtube_gdata
A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
If the system beeps:
If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card.
Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card.
wynndecks
I had this exact same problem, and I found a VERY simple fix to the problem.
Scenarios goes like this: Just got my new Video card and a PSU to accommodate the more demanding card. I install everything correctly and the computer boots up. I leave the room and come back to the computer shut down. Upon rebooting i see the error message "Alert! Computer has shut down due to a thermal event".
I am trying to let as many people know as possible before they start returning their merchandise or even worse, putting more money into a system that -should- work fine.
Okay enough with the fluff. Upon opening up the case I actually found that the culprit was a very small piece of lint was stuck in the connector for the fan, and upon removal of this, the fan worked perfectly and the world was a better place.
I am sorry if this did not help you at all, but if you are having this problem, please be sure to check this, as I know I was VERY close to returning the PSU myself as no one had mentioned this in any of the sites I visited.
iratemonkey
97
I have z97 1150 mobo, after thunder storm started issues:
Upon warm-cold bootup, staring at the CPU’s cooler’s fan saw that the fan would spin up, then run for half a second, then cycle down and stop spinning, then spin up again, then cycle down and rest and stop spinning, then spin up again, then etc and finally once get past the BIOS logo and into the TrueCrypt login does it spin up for good and get normal RPM. This may be due to especially cold weather and confusing the cooler into thinking that it does not really need to spin at all because the CPU is already too cold, or it may be the motherboard having issues and only supply intermittent power to the CPU fan until it finally slowly “wakes up and boots up” and initializes itself and finally stabilizes.
