cpu fan temperature
PCnerd21
119
I have the asus directcu ii with the i5 4690k, and the cooler master hyper 212. Is 40 degrees the right temperature for this build? Thanks for the help!
Is 40C at idle? It seems a bit high, normally you like to see around 30C but there are other variables like how hot is it in your room, how much humidity is around. 40 isn't a bad number. What are the numbers under load, should be under 80C. In the summer my computer runs around 40C in the winter around 30.
