cpu fan turns on for 1 second and then shuts down
Rene82
20
Hi There
I've had this system for 4-5 years never had an issue, suddenly went to turn it on and the CPU fan kicked in for about a second and then system shuts down
Below is my Rig, nothing has been touched or overclocked (only when I bought the system)
Anyone have any clue
im thinking either mobo or cpu is cactus
MOBO: ASUS Z87I-PRO (1150 Socket)
CPU: Quad core i5 4670K Haswell
RAM: G.SKILL 2 x 4GB 1866 MHz
GPU: 2GB Geforce GTX 760
PSU: 650W 80Plus platinum Antec
thank you for any advise
on most systems the cpu fan will power up first to keep the cpu from melting. the gpu fan on most rigs will spin up to 100 percent as a fan check the nslow down.
thank you, im about to finish work , so I will do process of elimination and provide feedback, I wonder if all fans kick in at once when machine boots up or if its in sequence, from what I recall, my cpu fan always started first, followed by case fans and then my GPU fan.
