CPU fans, LED lights are on but no signal coming out from USB, display, or mouse
Aug 23, 2018
I recently built my first computer. Everything was working fine, I was able to play games with no problem. until yesterday I started messing with the LED lights trying to give my computer case a better look. I believe that I wired the wrong cable to a set of LED lights that I bought separately, it sparked and shut down the whole computer. I was able to started back up and I got the lights working. Until on the BIOS, I clicked the section where you can choose which OS you would like it to run it from ( Windows 10 or SSD) and accidentally clicked on SSD and restarted the system, after that a error message appeared in a blue screen for a few seconds and then the message that says to plug a drive to run your BIOS and press any key. So I did, I plugged my disk reader with the windows 10 and the screen just went black. As the title said all of my fans and LED work but I'm not getting any signal out of any of the ports. Please help I already spend a lot of money I don't want to buy the wrong part or damage whatever is wrong even more.
Specs:
*AMD - Ryzen 7 1700 3GHz 8-Core
*Gigabyte - GA-AB350M-DS3H Micro ATX AM4 motherboard
*G.Skill - Ripjaws 4 Series 8GB (2 x 4GB) DDR4-3200 Memory
*SanDisk - SSD PLUS 240GB 2.5" Solid State Drive
*Asus - GeForce GTX 1060 6GB 6GB Dual Video Card
*Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply
*Cooler Master
MasterBox Pro 5 RGB case
