D despax Honorable Sep 10, 2013 6 0 10,510 Sep 10, 2013 #1 Hi guys, i ask about CPU temp and i see a lot of thread about but i still need to know I guess my computer is too hot : check this : Mother board : GA-970A-UD3 x.x bios: F7 Thx to you
D despax Honorable Sep 10, 2013 6 0 10,510 Sep 10, 2013 #3 what is this 87° Max i think before installing HWmonitor is cpu Upvote 0 Downvote
RobCrezz Expert Ambassador Mar 14, 2013 19,077 99 75,190 Sep 10, 2013 #4 run prime95, then see what the temps are while thats running. Upvote 0 Downvote
D despax Honorable Sep 10, 2013 6 0 10,510 Sep 10, 2013 #5 With prime 95 + Game path of exile + photoshop http://fr.d-spax.com/CPU1.jpg Upvote 0 Downvote
RobCrezz Expert Ambassador Mar 14, 2013 19,077 99 75,190 Sep 10, 2013 #6 I believe you dont want to go over 65'c on a 8350, but I cant find any concrete answers. What cpu cooler are you using? Upvote 0 Downvote
D despax Honorable Sep 10, 2013 6 0 10,510 Sep 10, 2013 #7 i use this : Be Quiet ! Dark Rock Advanced http://www.ldlc.com/fiche/PB00125099.html Upvote 0 Downvote
O oczdude8 Distinguished Oct 18, 2009 1,945 6 20,965 Sep 10, 2013 #9 tjmax should be 90c so 65c should be okay Upvote 0 Downvote
D despax Honorable Sep 10, 2013 6 0 10,510 Sep 10, 2013 #10 hum ok... sometimes in max temp i can see 250° but average 60° 65° for CPU I'm affraid my Computer burn 🙁 Upvote 0 Downvote
O oczdude8 Distinguished Oct 18, 2009 1,945 6 20,965 Sep 10, 2013 #11 no don't worry about that. That just some sensor error. HWMONITOR sometimes makes mistakes. My hwmonitor reads 81c max, when my current value is 31c, and my cpu is idle. Upvote 0 Downvote
