So i bought this pc https://www8.hp.com/gr/el/desktops/product-details/34111446 and when in idle the cpu temp is around 45 with a little trip to 50 degrees which i believe is fine im worried tho when i play warzone it stays most of the time around 75 but it hits 81 for like a second and then drops again at 67 where it goes up again.Is this something to worry about or are this temps fine?I do have the stock cooler and the case doesnt have that good of an airflow.I dont know if i want to change cpu cooler or adding a fan cause this may void the warrany and i also wanted to ask will this pc be able to last 3-4 years even more with these temps or it will be dead in a year with heavy games?I have also played asc origins which gets the cpu to 70 degrees.
AMD Ryzen™ 5 3500u
GTX 1660 6 gb
AMD Ryzen™ 5 3500u
GTX 1660 6 gb
