Okay so lets start out with how I used the Corsair h75 on my i7 5820k 3.30ghz a year and half and everything was great.
Until, recently I started to lag really bad. I couldn't really do anything, it didn't get to the point of shutting down itself however when I shut my computer off and turning it on again it would shut down after a few seconds. So I thought I might had a virus or malware that had affected it. So I hard format my computer and during the process I got this message: "Package temperature above threshold, cpu clock throttled total events = 90323." I went online and checked for solutions... and I came to a conclusion that it could be my liquid cooling either the pump had stop working or the thermal paste was used up. I bought a new liquid cooling the Deepcool maelstrom 240 and I had just installed it. Now I noticed my temp haven't really decrease that much... I still peak 80~ degree C when I only stream twitch. The H75 peak near 88-89C.
I used the stock thermal paste so perhaps I need to add more if I want to achieve a lower temp? would this help?
I was hoping that having a dual fan would make a big difference... and with that I was hoping that I would be able to overclock it... but seeing the temp is still so high I don't think i'll be able to overclock it anymore.
My question is, am I doing something wrong?
What's the "normal" temp for i7 5820k 3.30ghz?
Is there anything that I could improve and hope that maybe I could reduce the temp on my cpu so that I could possibly overclock it?
Also I was wondering my H75, one of the "hose" gets extremely hot and the other one stays cool...
is this normal? or does that mean that it isn't pumping correctly/it's clogged? if so is there anyway to save it?
I noticed the Deepcool maelstorm both of the "hose" stays relatively the same temp so.... ya
I would like to also note that the temp that I got on my H75 once I turn on the computer and turn on speccy I get a reading of 86+ Degree
