CPU/GPU Fan Spins No Display
bctest786
Hi Guys,
GPU: Zotac 1060 6GB-1, Zotac 1070-1, Zotac GT210
CPU: AMD FX4100
RAM: 20GB DDR3 Corsair RAM
Motherboard: Gigabyte GA-970A-DS3
SSD: WD 120GB
PSU: Antec 750watt
I am facing a weird issue with my computer. I was using only one card (Zotac GT210) earlier then I added 2 more card (1060,1070) after that it stopped giving me display on the screen.
I tried many things like removing GPU's that I recently added, swapped RAM slots, checked power supply etc but that didn't helped.
If I restart the computer or shutdown and try to restart then it won't give any display and I have to pray to god for the display to appear.
I also tried to reset BIOS and it didn't worked either.
Is there any issue you guys are aware of that I need to look into?
Thanks!
Motherboard could be shorting in your case... try powering on with motherboard out of the case and see if it will work, also dont forget to connect everything as usuall doing this and be carefull
