CPU/GPU Issue when running games
Cam Richards
I recently switched my old components into a new, much larger, case. Before the move I had no problem with frame-rate on CS:GO, 200-300 fps, or Borderlands, whatever frame-rate I set. However after the transfer I noticed a severe drop in performance. looking into it I noticed that the GPU is used for the first maybe 30 seconds then it drops down to about 15-20% usage and the CPU picks up to around 80-100% usage and high temps. I have no idea why it does this, and it is highly annoying because it worked perfectly before I transferred it over. Any help/ideas would be appreciated!
It ended up being the thermal paste, just reapplied and back to normal. Thanks!
