CPU & GPU overheating problem
Doruko
First of all, sorry for bad english...
Well... since today (a bit after installing Battlefield 4) i've started having an overheating problem, both CPU and GPU arrives at 80º C, without doing nothing, just power on the PC, and the temperatures start growing..., i've put again thermal paste on the CPU, also i've relocated the CPU & GPU...
Any ideas on what's happening? (I've desinstalled BF4 [just in case] but still happening).
EDIT: here's a screenshot of the temperatures and the performance:
https://www.dropbox.com/s/w4vaur0wu4le3o3/Sin%20t%C3%ADtulo.png
diazalon
764
90
What is the temp in your room? Is it clogged with dust in the fans?
The gpu temp is fine and normal
The cpu is the concerning factor. What cpu cooler?
diazalon
764
90
Hmm thats odd what is the temp in your room?
Try re applying some good thermal paste on the cpu that should help, something like MX-4
Doruko
This is the thermal paste just applied http://voccat.es/35100001-16294-large/pasta-termica-deepcool-z3-15g.jpg, and it worked fine until today :(
RobCrezz
Herald
Turn the pc off and let it cool for a few mins, then start up and go into the bios and the temps there.
Its possible you could have something running in windows which is loading your GPU/CPU causing all the heat.
diazalon
764
90
That is not a good brand for thermal compound. Did you clean off the old stuff first???
Doruko
Yes, i did. Now i'm going to try to pwer off it and going to the BIOS
Doruko
I did it, the temp starts arround 50, but it grows up until 80
RobCrezz
Herald
Ok, well if its heating like this in the bios, then your CPU cooler isnt making a good connection, or you have something blocking airflow.
It should not be rising like that in the bios.
Doruko
I've unmounted and mounted the CPU like 5 times, and the airflow is good, i have the case opened.... what should i do? Look for a new cpu? :S
Doruko
Yes, the one that comes with the cpu
Doruko
I've changed the CPU cooler with another (worse) but it works fine now (between 40-45º C), but the GPU stills getting hotter
Similar threads
