CPU & GPU temps when benchmarking
Fuzzmonster
9
Hello all. This is my first post here.
I finished my first build & decided to try some benchmarking & I noticed that both my CPU & GPUs temps were in there mid 50s. I had all my fans at full spin & was expecting something a little lower, but since this is my first build I have no idea what temps would be optimal. (That said I have tried to research it, but to no avail)
Here are my specs:
CPU--- i7-4790k
GPU--- Gigabyte GTX 980 G1 gaming
CPU Cooler--- NZXT Kraken x61
Case--- Corsair Graphite 760T
Benchmarking software--- 3DMark FireStrike
Fans--- 3 case fans(not including kraken fans)
My idle temps are:
CPU--- 26c
GPU--- 28c
Thanks in advance!
The speed of response is insane!!
Thank you every one and I'm glad that my temps are fine. I suppose the best answer should go to the fastest answer, but thanks to all of you.
