CPU Heatsink fan can be used as case fan??
Makers
Commendable
Mar 16, 2016
7
Here is the pic of the fan http://puu.sh/sLFZc/762691f74c.jpg.
I was wondering if i can use this as a case fan.. i have 2 piece of these.. can it be plug on the power supply? My power supply is a Corsair VS 450.
Update: Here's a much better pic. http://puu.sh/sLGnS/1742c9fee7.jpg
Yes. I don't know how you will plug it into the power supply unless it has fan headers or you have a molex adapter or something, and if you plug it directly into the psu it will run at full speed all the time and probably be quite loud. Plug it into the motherboard if you have an open chassis fan header.
Thank you Sir's for your replies... My Case is a Silverstone Sugo SG13B. im planning to put both here.(https://cdn.pcpartpicker.com/static/forever/images/userbuild/184158.f755b184fe53cdb578082f59e33c352e.1600.jpg) outside pushing air towards the gpu. I already have a 120mm fan at the front and I will make it as an exhaust fan since the two cpu fan will be the intake. Is that a good idea? I already checked for any adapters here in my place but it is not availabe... can i redneck-ly connect it directly to the molex? what wire color should it be?
