cpu heatsink fan making noise even though i dusted
sioni90reggae27
50
I recently been experiencing noise coming the front fan of my Cpu fans.
Even though I dusted the dust behind the fan the sound still persists...
I restart my pc and it goes away but before I cleaned it wouldnt go away...
I feel the dust only fixed some of the problem... Could my fans be dying?
The only way I could kill the noise is if I stick my finger and skip the fan...
I removed the dust bunny behind the 1st fan and used a toothbrush to brush it...
its not clogged it just had a bit of dust on the cpu cooler
Should I buy a new cooler? What do you suggest?
Cooler Master Hyper D92 - CPU Air Cooler with Dual 92mm Offset Push-Pull Fans and Accelerated Cooling System
https://www.newegg.com/Product/Product.aspx?Item=N82E16835103108
pc specs.
asrock b250 gaming k4 motherboard
intel i7 7700k cpu w/ hyper d92 cpu cooler
what does the fan sound like? a fly buzz? a grindy whirl? an electrical whine?
fly buzz is caused by fan blades rubbing agianst housing
grindy whirl and electrical whine may point to coils or bearing wear. if you can use your finger to push the fan blade 'past' a sticky point to resolve the noise issue = bearing wear.
get new fan
