Hello all
I have an athlon 64 x2 5200+ (2.70ghz) 65w
ram 3gb ddr2 800mhz
nvidia gt 610 1gb
Asus asrock N61p-s(the mobo have features for oc )
and other
But on my case i have a screen for temps and is showing 44.5c for my cpu,i downloaded speedfan and there CPU is about 7-10 more,is it a normal temp or its a little high,and i change my cpu cooler the stock replaced with Deepcool Gammaxx 200 also i have a deepcool case fan wind blade 80mm led blue who is sucking air,the cpu is cleaned and new thermal everything is ok,I want to overclocked it and i dont know to do it or not because of the temps!! Can someone help me ? And who is correct the speedfan or the other screen on my case in front? Thank you
ram 3gb ddr2 800mhz
nvidia gt 610 1gb
and other
