[SOLVED] Cpu high temperature in gaming 54c to 63c,66c,69c,73c max
Dec 10, 2020
18
I7 9700K @ 4.9Ghz turn on all core's 4600mhz it's running in gaming
Sapphire NITRO+RX 5700 XT oc GDDR6
16GB ddr4 ram @ 3600mhz mhz Trident z RGB dual channel
Z390m gigabyte UD
1TB m.2 SSD Aderlink
250GB m. 2 SSD XPG 6000pro
650w watt psu max Antec
Monitor 1 1920x1080p 60hz & dynamic resolution 2560x1440p
Windows 10 Pro 64bit updated.
RGB casing fan's etc, 4 fan's RGB lighting fan's in front 3 up 1 & back sensor fan installed why my cpu temperature goes high peak 54c to 58c, 59c, 60c, 63c, 64c,66c,69c,70c,73c max in gaming like Gta v, Metro Exodus
Cpu cooler is Contac 9 29B Tharmaltake with 1 fan
That sounds pretty normal, the temperature is closely linked to how much work the CPU is doing at that moment and will fluctuate up and down under normal conditions, CPU work loads during gaming can fluctuate quite a bit.
