I recently had a computer built by my Girlfriends father. I myself am fairly computer literate but he is much more experienced with building systems. The system is a ASUS P8Z68-V motherboard with an I7 2600k chip. When I got the system it ran great and it still does. It seems to have no flaws. I wanted to make sure the temperatures of the GPU were okay while gaming so I downloaded a monitor tool called "Open Hardware Monitor" When I checked the GPU temp it was perfect, but I noticed the CPU Cores hitting 90C Max while playing the new Star Wars. I even found one core that hit 96C Max... My girlfriends Dad told me to go buy a better cooler as the system was only using a stock Intel cooler. I looked online and found stock or not it shouldn't be running that hot. I tried re-seating the Cpu, then I tried cleaning the CPU and re applying thermal paste, but it made no difference.. I went out today and bought a water cooler. I installed the new cooler and it helped the temps a bit but the cores are still hitting 80C with a CORSAIR Hydro Series H60... I'm almost positive it's installed right. I noticed on the hardware monitor there are a few different readings. There is a tab for what my motherboard is saying the CPU temp is then there is a tab where my CPU is telling me what its temp is. The Motherboard tab Says the Core CPU Temp is 40C right now. The I7 tab says the Cpu Package temp is 54c right now. Should I be worried about the temps, would the sensors maybe be off? If someone could please give there input on if this is okay that would be great. By the way the CPU is overclocked to 4.2GHZ so it will not bottle neck when I play games... I tried setting the clock speed back to stock but it didn't help the temps much so I just left it overclocked. Thank you.
