CPU idling at 70C, HELP PLEASE!!!!
lukcio
4
My CPU is idling at 70C according to HWmonitor and I cant figure out the issue. I've tried replacing the thermal paste(arctic silver 5) and it hasnt helped. Also, when i put my hand above the radiator where the air blows out, the air temperature is cool. Can someone figure out this issue? Is there a problem with the temperature sensors? Here are my specs:
MB: MSI Z97 gaming 5
CPU: Intel 4790K
GPU: MSI GTX 980
COOLER: Corsair H100gtx
it must be the pump its not working . try shaking the pipes if that helps
and in corsair link is it showing PUMP RPM?
I tried shaking the pipes of the cooler and the temperature read about 58c at idle, but it should be under 40 at idle. Also, the pump rpm according to Corsair link is 1980 rpm.
I checked this and could not feel any vibration. I will contact Corsair like you said and hopefully u can get a new unit. thanks!
http://www.tomshardware.com/answers/id-3453578/randomly-high-temp-4670k-corsair-h100i-gtx.html
you have the same issue as i had last week i hate this AIO..... i bought now the Cooler Master Maker 8 Cpu cooler and i am happy with it no need to worry that it will fail or pump stop working...
I have decided on a noctua nh d14 for my cooler. Reviews say that it's great.
