[SOLVED] CPU Installation With Liquid Cooler
Thank you, Just for clarification which mount should I be using with regards to the instructions.
https://support.arctic.de/lf2-240-argb#1200
Should it be the standard mount or the offset mount?
According to the instructions Ryzen 3000 cpu should use offset, which I see now you didnt do. When you change it it will probably cover your cpu. Good catch. 👍
