Cpu is running but not booting
ttytbalboa
4
It started last week, firstly monitor was showing “please powerdown and connect pcie” but now everything is running like proccessor fan, gpu fan and everything but no booting just showing “hdmi:- inactive, input going for sleep
Gpu:- gtx 1070
Ram:- 20 gb(ddr4)
Proccessor:- i7 7700k
Motherboard:- msi h270m artic
its the gpu i would say iv seen many of people with the same issue you are having. load default bios and save take the cmos battery out for about 10mins. plug hdmi into mobo first then go to bios select your gpu as the first choice then post back if still having this issue
ttytbalboa
4
Actually i had removed the gpu and connect hdmi cable to motherboard after that it was working but next day it had also showed same problem and not starting. So could it be the problem of motherboard? I mean should i change the motherboard or should i change psu?
ac13044
846
