cpu issue/concern help
Xendrix
6
Acer Aspire 5251: GB ram 2x4gb v120 AMD series
Recently i just received a brand new AMD Athlon dual core p360 i meant to buy AMD athlon dual core n330 but they are just about similar. and so i switched it with from my v120 amd cpu.
After the p360 was installed my computer would show a black screen: nothing else but a black screen. sometimes the fan would run for few seconds then shutoff. and if i boot without the power supply in it will run fine but the screen is still displayed black.
i think its the p360 but compatibility list from CPU upgrades said that my AMD motherboard supports Athlon dual cores and phenom quad cores...and in the comments someone already confirmed it worked better then he thought. I dont have enough to buy another...and n330/p360 are just about same. just want to get some suggestions on how to fix the black screen so i can use my new p360.
