CPU Led won't turn off sometimes
Hello,
The cpu led on my gigabyte aorus b360m gaming 3 is on sometimes. When I restart it is on, when I shut it down then turn on again it was off ( at first all the time,now sometimes) and when I put it in sleep and then wake up it if off. My system is fine and everything works it's just the light. Its my first pc and I'm still learning so has anybody an idea what I can do about this led?
Thank you in advance :)
asoroka
1,201
228
If the light is on, means the PC is not off.
It may be in some sort of sleep state.
You need to check your OS and bios settings to make sure that power button actually powers computer off rather than puts it to sleep.
Windows -> Control Panel ->Power Options-> System settings-> Power button Settings
Nov 4, 2018
I looked at but it just said shutdown, but I did disable fast startup. Unfortunately it still gives a red cpu led after shut down. Once it's been in hibernate or sleep and then woken up it's off. Very strange.
