Cpu Light then dram light
590gaming
Hi There! I have just built a new Gaming PC and when I boot up the PC all fans turn on. But in the top Right of the Motherboard the cpu light flashes then the dram light, is that normal? If not how do I fix this issue.
Specs
I3 6100
Gtx 1050
1x 8gb Module
Intel Stock Cooler
450w ps4
Msi Motherboard.
Also where should the CPU 4 pin cable be? Because there is no where else it could go and the text above it says jsw2 or something like that
