CPU Liqued Cooling, Where do I plug the pump into?
ChrisWKuiper
46
Ok so I have a Corsair h105 liqued cooler for my cpu, and I dont know where I should plug everything into. I have the cords for the fans on the radiator, and the cord for the pump block. I know that the pump block is supposed to be running on a steady voltage all of the time, but I dont know what pin on the motherboard I should plug it into to give it constant voltage.
I was going to start with plugghing the fans on the radiator into the cpu fan slot, because those need to be able to change speed with the cpu temp anyway. Where EXACTLY should I plug the fans and the water block into?
My motherboard is the ASUS maximus 7 hero, and the cooler is the corsair h105. Thanks.
Looked it up in your motherboard's manual (it helps if you know what you're looking for tbh), CPU_FAN and CPU_OPT vary according to temperature. Use one of the other ones.
Ok thank you.
