K Kristofer_2 Honorable Dec 31, 2015 65 0 10,640 Feb 6, 2018 #1 NZXT Kraken X62 Rev 2 or Corsair H115i PRO?
Solution Dark Lord of Tech Feb 7, 2018 Corsair H115i PRO is the winner with it's new pump design and cooling ability.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,726 1,820 159,590 Feb 6, 2018 #2 Corsair H115i PRO X62 is quite noisy. Upvote 0 Downvote
jacobweaver800 Respectable Dec 15, 2017 1,539 0 2,460 Feb 6, 2018 #3 Kristofer_2 : NZXT Kraken X62 Rev 2 or Corsair H115i PRO? Yeah, i'd recommend the H115i Pro. Upvote 0 Downvote
K Kristofer_2 Honorable Dec 31, 2015 65 0 10,640 Feb 7, 2018 #4 Corsair H115i PRO X62 is quite noisy. Performance > noise. Which performs better? If it's still the Corsair H115i PRO, then it's a different story. But I (personally) am not too worried if the cooler makes a little noise. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,726 1,820 159,590 Feb 7, 2018 Solution #5 Corsair H115i PRO is the winner with it's new pump design and cooling ability. Upvote 1 Downvote Solution
K Kristofer_2 Honorable Dec 31, 2015 65 0 10,640 Feb 8, 2018 #6 Corsair H115i PRO is the winner with it's new pump design and cooling ability. Awesome! Thank you! Upvote 0 Downvote
K Kristofer_2 Honorable Dec 31, 2015 65 0 10,640 Feb 15, 2018 #7 Corsair H115i PRO is the winner with it's new pump design and cooling ability. You're a senior moderator; therefore, you know what you're talking about. Would you mind checking out this thread? http://www.tomshardware.com/answers/id-3633634/microsoft-flight-simulator-bugging.html Upvote 0 Downvote
