presse1
39
I'm abou to try to overclock my new system build i7 920 cpu but I figured I would run prime 95 first for 15 minutes. At load my temps average 63 degrees C with the low being 60 and the high being 65. Is this normal preoverclock? I know the overclocking guide on toms says you shouldn't go over 75 degrees at load and that worries me as I only have 10 degrees to spare from that.
Kewlx25
My 920 hovers around 65-70c with stock HSF under load.
Here's some CPU temp ranges
60-65 great
70-75 good
80 decent
85 bit warm
90 better start ice me down
95 it's getting hot in here, is the fan on?
100 Thermal Throttling kicks in and water starts to boil
(centigrade)
