[SOLVED] cpu low usage in RDD2
If you play at 1080p then the resolution scale needs to be at 1.0. If you go over 1.0 it means that you are running DSR and go over 1080p resolution.
At 2.0 it would mean you're running the game at 3840 by 2160.
DDR4. Not DDR5 😉
DDR4. Not DDR5 😉
