Cpu max temp too high?
hxrvj
35
I just launched up my computer and my max temp is 68 degrees is this normal??
CPU: I7 7700k
hxrvj
35
Celsius
CPU: i7 7700k
GPU: GTX 970
CPU COOLER: Be Quiet Shadow Rock Slim
Thermal Compound: A bad one.
hxrvj
35
CPU: i7 7700k
GPU: GTX 970
Its 68 Celsius but could it be this high because of all the things that are starting up on launch?
hxrvj
35
CPU: i7 7700k
GPU: GTX 970
68 Celsius could it be this high because of all the programs starting up on launch?
hxrvj
35
no it never stays that high it only reaches that high for about not even a second?
hxrvj
35
ohh yes good I was hoping so bad that it was normal yes I run at about 32-45c
hxrvj
35
Ok thank you so much. :)
