Question CPU maxes at 40% load and 1.39ghz clock speed
Nov 25, 2019
Hello!
About a week ago I noticed that my computer started running alot slower than usually. So I checked my cpu speeds in the task manager and noticed that the cpu is running at 1.39ghz when its supposed to be running at 3.5ghz. I also noticed that when I try to play games or if I perfom a cpu stress-test, it doesn't ever go above 40% load.
I even bought an SSD today to see if that was the problem and reinstalled windows on it, but no difference.
When I enter windows safe mode however, it runs at normal speeds.
I have pretty much tried every solution that I could find online but nothing works. The cpu is cold (around 11 degrees idle) and i've disabled all power saving in BIOS. Do you guys have any ideas? Is the hardware done for?
Here are some images of bios and such:
View: https://imgur.com/a/I12FgZE
CPU: AMD FX 6300 6-core
Motherboard: Gigabyte GA-970 gaming
GPU: Msi 1060 3gb
Ram: 16gb DDR3
Psu: 550w gold
Cooler: Noctua NH-D15
Nov 25, 2019
It won't be 11C idle on non exotic cooling unless you have a room at 0C. I think that it's throttling.
Okay, throttling as in too high temperature? Why does it show as 11 degress? :O
I just bought a noctua nh-d15 to see if cooling was the problem, but the speed didn't make a difference when I installed it :s
Thank you for your answer btw!
