Question CPU Memory limit and onboard memory speed
agate2
51
I just purchased AMD Ryzen 5 3400G CPU , specification says that it support up to 2933 MHz DDR4 memory
I have purchased DDR4 3200 MHz memory, will this CPU work with that memory.
The board I will be using is Asus ROG STRIX B450-F gaming
Thanks
Thanks
Yep, just could not perform as 3200Mhz behavior , but not a really great problem.
Underclock is not a problem for every device, rather than overclock/oV
Reactions: agate2
Yes, it will work, and you can probably run it at 3200 MHz too. 2933 MHz is the officially rated memory speed for that processor, but that doesn't mean you can't run higher (it's just technically an overclock).
Just enable the XMP profile in the BIOS (may be referred to as DOCP), with any luck you'll be running at 3200 MHz without issue!
Reactions: agate2 and zSynt3x
