Cpu no cooling properly
arsh21071977
I managed to clean my cpu fan of core 2 duo e7500 but when i was putting it down one of the pin broke
I fixed it qith superglue and the alignment was ok
But the temp of cpu rose from 85 c to 100 degree celcius at stress testi could not find the problem
Could it be because 1white part broke??
Plz help me
ahh are you talking about the pins that mount the cooler to the mobo. If so breaking this would possibly cause your heating problem yes. The heat is not transferred from CPU to cooler efficiently if there is any reduction in the contact between cooler and cpu. even if the pin has been repaired well there may still be a small amount of separation and millimeters can cause a large difference.
