CPU Not Changing Speed During Idle?
Apr 9, 2013
50
I have a 4690k running at 4.4Ghz at 1.191 volts. The voltage is set to adaptive on my MSI Z97S-SLI Plus Mobo. Intel Speedstep is on too. The thing is, I used to have it running at 4.2Ghz at like 1.14 volts, and when idling the CPU would lower it's voltage and speed accordingly. But now it doesn't, when all I did was change the multiplier and core voltage. Is there any reason why my CPU is running at 4.4Ghz @ 1.191 volts 100% of the time now? What can I do to fix it?
the newer boards are a bit different. You need c-states to be enabled when overclocking or it wont work. If you weren't overclocking and you left stuff on auto then it would.
Do I do this in the BIOS under OC Settings?
Turns out that windows wasn't letting the CPU back down from 100% speed, so I changed that setting and it works, albeit it only clocks down to 4.1Ghz :/ I couldn't find anything in the BIOS about min/max voltage/multiplier
I just changed C-States from auto to enabled, but left another c-state option on auto, I forget what it's called...I'm gonna screenshot the BIOS real quick
I've got it fixed now, Thank you. It was actually on Windows side for whatever reason. I appreciate all the time taken for you to help me out.
If curious, I changed my power plan from the recommended on to something more useful to me. In the advanced options, there's a min/max CPU option and I had mine set to the same as the recommenced balanced plan (5% min). For whatever reason, switching it back to the balanced plan that came with windows allowed the CPU to underclock. So yeah.
