CPU not detected or fail
Tried 1 stick of RAM, all connections seated, ect? Try onboard video with GPU removed? Using bare minimum hardware can narrow down. I'm assuming all hardware is new. However, a quick search sounds like it could be the UEFI needs updated to support the Ryzen 5. The old versions only support Ryzen 7. The problem is your board needs a Ryzen 7 to update the UEFI to support the Ryzen 5 if this is the case. Some boards can do this without a CPU installed, but yours isn't one of them.
Ryzen 5 1600
Asus GTX 1070 8GB
16GB 2 X 8 RAM DDR4
1TB Harddrive
MSI B350M Motherboard
The debug led for no CPU detection or fail is constantly on.
Have tried powering off and taking CPU out and putting all back in and still nothing.
MERGED QUESTION
Question from georgejosephballard : "RYZEN 5 1600 CPU Issues Please help"
If it doesn't, do you think it may be the motherboard?
