Recently, I started having some overheat trouble. After having my system for a couple years with very nice running temps, the effects were noticeable. Especially since it was causing lock-ups/shutdowns.
Opening it up, I discovered an oily substance on the motherboard. (MSI 970 Gaming) With a bit of research, it seems as if this is linked to CPU issues, so I went ahead and ordered a replacement motherboard. (Same model.)
Got the new board. Got in installed. CPU is running at 18*c.
Only it's running at 1.38 Ghz.
This is an AMD FX-8320 octa-core, with a 3.8 GHz core speed.
After looking for a solution to this puzzle all day, I found (via CPUID) that the multiplier is only at 7. This should be 17.5. BIOS states a multiplier of 17.5.
Windows says it's 3.8 GHz under the system menu.
Novabench also reports 1.38 clock speed.
I've got 16GBs of memory. This system has been running since I built it with no changes. I've already set power profile to High, etc. No cores are parked. Drivers are up-to-date. Windows has been reinstalled.
It works fine for internet. But then again, so does the Intel Celeron 2.4 GHz machine I got sitting in the closet.
I go to try and run a game, and the cpu issue is extremely noticeable. The game wants 2.0 GHz, minimum, so that's understandable.
Any ideas? I would like to solve this quickly, as I do have a grace period on the motherboard where I can get my money back. If this turns out to be a fried CPU, then I'll need to take advantage of that and start saving to build a new PC.
Thanks for the help.
