CPU not running at full speed
crisan_tiberiu
1,185
set your PC power plan to "high performance" in windows when you do heave workloads on your PC. There might be another issue, if you run heavy workload on your CPU for a long time, the CPU might get very hot and then "thermal throtling" kicks in and reduces your CPU speed to reduce the heat.
dman4x4
12
This made big difference, CPU Speed now went up to ~1600MHz, not bad, but still not 2.4GHz.
bigmike1
8
for some reason i have speedstep off and thermal throttle off and high performance mode on, but now it wont run 3.8 ghz on my i53570k, it used to a few days ago and nothing changed, pc is a shitty platfrom
crisan_tiberiu
1,185
Disabling Speedstep you also disable "Turbo boost", witch ofc is a "C step". Before accusing the PC beying shitty you should check the part betweeen the PC and the chair :)
