Question CPU not same heat as before and FPS drop?
Jan 5, 2021
13
Hi everyone,
I have a question. A few weeks ago I suddenly had to deal with an FPS drop. Where normally frames are reached around 150 (for example warzone), I now suddenly have around 10 to 40. The reason for this is unknown to me. Could it be because of the latest NVIDIA update which I did? It sometimes seems like my CPU is not getting proper heat. The video card works normally. Could there be a problem with the CPU why it is not working well?
When I use Speccy I see the following (http://speccy.piriform.com/results/j0A60TwwLpZmAPtRVUyQgNg)
RAM 32,0GB Dual-Channel Unknown @ 1600MHz (16-18-18-36). But the RAM I have is Corsair Vengenance RGB Pro – Geheugen DDR4 - 32 GB: 2 x 16 GB - 3200 MHz - CL16 - 1.35V
I have adjusted the setting in the BIOS using XMP 2.0. So that should be good.
I hope someone can help me.
With kind regards,
Rick
Jan 5, 2021
13
Did anything happened during that drop ? Power outage, new components?
What is your PSU ? How old is your system ? Can you run userbenchmark and post results.
Thank you for your reply.
Built the computer myself, almost 9 months ago. No problems from the moment of starting up until two weeks ago when I did a Nvidia update.
PSU: CORSAIR RMx Series RM850x - 2018 Edition ATX12V 2.4/ EPS12V 2.92 - 80 PLUS Gold - 100-240 V - 850 Watt
UserBenchMark - says missing GPU:
https://www.userbenchmark.com/UserRun/38010065
Also did run Unigine_Heaven: only thing I see is GPU Model (4095MB, when its 8GB?)
https://ibb.co/X5TdCmX
I just don't get it why games like Warzone and Valhalla are not running well..
Jan 5, 2021
13
Something is wrong with your gpu. Didn't even get detected in userbenchmark. They rolling back to the old drivers. Is it overclocked ?
There is no overclocking. I think it's purely because of the latest update from Nvidia. Maybe when an update comes that it is fixed.
