cpu or gpu upgrade?, help me please :)
maxkc69
9
So I am currently rocking an fx 8320 CPU with a 960 2GB model (16GB ddr3 RAM too) I'm really looking to upgrade my system so I am able to start streaming games such as CS:GO and maybe some fortnite, I don't have the most amount of money, an I am fully open to buying second hand instead of first hand (if need be). I don't have a specific budget, but it would be anywhere in the region of £150-to £350 at the most. Any responses are greatly appreciated :)
~Max
You can't upgrade CPU without switching to fully new platform (CPU, motherboard and RAM). And changing GPU won't help with streaming at all, besides gtx 960 is still respectable card (anything noticeable better would use up all your budget). So tough choice.
Would it be a good choice to buy a second-hand i7 4790k + motherboard bundle? so that the insane RAM prices do not affect me?
Certainly that's an option worth considering. The only problem would be you have no idea how long second hand components will work. While CPU should not be a problem, but motherboard can be. It would be a real pain to lose a machine to a motherboard failure say 2-3 months after purchase.
That is a dead platform too, although it is a lot better than the 8320. I would point you to the AMD Ryzen lineup for streaming. You don't need 16gb of RAM, 8gb will be enough for CSGO and Fortnite. I would go with this and you will be under 350 and will stream like a champ.
PCPartPicker part list: https://uk.pcpartpicker.com/list/HVcGD8
Price breakdown by merchant: https://uk.pcpartpicker.com/list/HVcGD8/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor (£137.94 @ Aria PC)
Motherboard: Gigabyte - GA-AB350M-Gaming 3 Micro ATX AM4 Motherboard (£65.99 @ Aria PC)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3200 Memory (£97.50 @ Aria PC)
Total: £301.43
Generated by PCPartPicker 2018-05-16 17:27 BST+0100
I was recently reading some of the newegg reviews on 8th gen processors.
I noted that there were several that noted a big difference using a 4 core i3-8100 over their previous FX-8350:
https://www.newegg.com/Product/Product.aspx?Item=9SIAB276SG6918
You can buy a bundle with a i3-8100, 8gb of ddr4 and a z370 motherboard for £269.99
https://www.amazon.co.uk/Coffee-Motherboard-2400MHz-Crucial-Pre-Built/dp/B07BMC1PMW/ref=sr_1_2?s=books&ie=UTF8&qid=1526488603&sr=8-2&keywords=i3-8100+bundle
I don't know if this is what you should do, but it fits your budget.
If your budget is a bit better,
you can buy a 6 core i5-8400 bundle for £359.99
https://www.amazon.co.uk/Components4All-Motherboard-2133MHz-Crucial-Pre-Built/dp/B07CN3TNWB/ref=sr_1_1?ie=UTF8&qid=1526488670&sr=8-1&keywords=i5-8400+bundle
First, though, take the time to do o few tests to verify that a cpu upgrade is what you really need.
Here is my standard text for that.
In particular, test to see how many threads you really need.
For many threads but lower clocks, ryzen is hard to beat.
Some games are graphics limited like fast action shooters.
Others are cpu core speed limited like strategy, sims, and mmo.
Multiplayer tends to like many threads.
You need to find out which.
To help clarify your CPU/GPU options, run these two tests:
a) Run YOUR games, but lower your resolution and eye candy.
If your FPS increases, it indicates that your cpu is strong enough to drive a better graphics configuration.
If your FPS stays the same, you are likely more cpu limited.
b) Limit your cpu, either by reducing the OC, or, in windows power management, limit the maximum cpu% to something like 70%.
Go to control panel/power options/change plan settings/change advanced power settings/processor power management/maximum processor state/
This will simulate what a lack of cpu power will do.
Conversely what a 30% improvement in core speed might do.
You should also experiment with removing one or more cores/threads. You can do this in the windows msconfig boot advanced options option.
You will need to reboot for the change to take effect. Set the number of threads to less than you have.
This will tell you how sensitive your games are to the benefits of many threads.
If you see little difference, your game does not need all the threads you have.
It is possible that both tests are positive, indicating that you have a well balanced system,
and both cpu and gpu need to be upgraded to get better gaming FPS.
I currently am using 450w PSU from Corsair, fairly basic
