Hi, i'm new to this forum and in some case im new to PC knowledge. Sorry for my grammars, if i don't write it correctly. My main language is Romanian. I tried to overclock my CPU, and when i changed voltage to 1.095, and to 1.200 it keeped running (The CPU voltage is 1.089 automatically) the BIOS started to lagg a bit, temperature doesn't changed, it stayed at 34C (It was 38C when i changed to the higher voltage or idk.) (I do know that i'm noob about this.) And the problem started. Restarted computer and on startup only the UEFi BIOS shows up, no Windows bootup, and Windows couldn't boot. And i went to keep the voltage at 1.089. SATA ports were enabled in the Advanced option, SATA configuration. And after this my Hard drive wouldn't show up in BIOS, in the Boot Menu too.
Details: HL-DT-ST DVDRAM GH24NSC0
RAM: Corsair 4096MB 1333MHz 4GB DDR3
CPU information: +30.0°c, +86.0°F, Intel(R) Pentium(R) CPU G3240 @ 3.10GHz Speed: 3100MHz
Motherboard: ASUS H81-PLUS
BIOS version: 2105
SATA information: SATA6G _1 (Yellow) Empty (Here i did put the Hard Drive SATA cable, 6G/s cable, Black)
SATA6G_2 (Yellow) HL-DT-ST DVDRAM GH24NSC0 ATAPI (DVDRAM, Black 6G/s cable)
SATA3G_1 (Dark Brown) Empty
SATA3G_2 (Dark Brown) Empty
SATA mode: AHCI
DRAM Timing Control: 9-9-9-24-1
CSM: Enabled
Computer: Hanns G HQ191D
If needed i will check out the hard drive name and model. Please any suggestions. Thanks
BIOS version: 2105
SATA mode: AHCI
CSM: Enabled
