My motherboard typically doesn't actually save my overclocking settings (Gigabyte X99 SLI board) unless I use a Windows program to overclock (Gigabyte's own EZ Tune software, go figure). Beyond just getting the actually BIOS overclocking to work, is 4.2GHz on a 5820k running 1.226V good? EZ Tune wouldn't raise the clock any higher and I'm assuming it lowered the voltage to the lowest it could at that clock speed. It's worth noting that I used the AutoTune feature instead of just using any of the presets.
