Hello,
I tried overclocking my system, but after I save and exit BIOS the computer reboots to a black screen with my GPU fans going at max speed. I tried decreasing the multiplier, increasing/decreasing Vcore, increasing/decreasing input volts, using the auto clock set to 4ghz, tried with speedstep and turboboost enabled and disabled all to no avail. I'm at a loss as to what would cause the GPU to do that when I'm messing with CPU settings. I can reset the CMOS settings and it will boot back up no problem. As it sits nothing is overclocked. Temps at idle and load respectively while stock: CPU 30/50 GPU 45/70. It's never done this or crashed stock only when trying to OC the CPU.
I was attempting to start at 40 multiplier with 1.05-1.2 volts, 1.75-1.9 input volts but all with the same results
Build:
Intel I5 4690K 3.5ghz (3.9ghz boost)
ASrock z97 Extreme4
CM 212
4x4gb ddr3 1600
Sapphire nitro r9 390
Rosewill ARC 650
Appreciate any advice. Thanks!
Build:
ASrock z97 Extreme4
CM 212
4x4gb ddr3 1600
Rosewill ARC 650
