Hello,
I build my brother a PC about 2 weeks ago and during that time, about once every 3 days, the pc would just randomly go to a black screen during games and periods of load. To find out what was wrong with it I ran some benchmarks and noticed that the CPU was going above 85 degrees Celsius during this tests and causing the tests to terminate. I then went into BIOS and noticed that the CPU was about 72 degrees Celsius while just in bios not doing anything(idle). I'm using a stock cooler and as far as I can tell all the fans are working correctly. The CPU thermal paste is also the stock paste that comes pre-applied.
I've got a i7 4790K with the stock fan and paste in my build and when running the same tests the CPU never goes above 60 degrees and is 30-40 idle.
The CPU is not overclocked nor is the GPU. Any help would be appreciated. Thanks
CPU: i5 4690K
GPU: GTX 970
Motherboard: Gigabyte GA-H81M-HD3 Socket 1150
PSU: EVGA 600 W 80+ PC Power Supply Unit
RAM: HyperX 8 GB 1600 MHz CL9 DDR3 HyperX Beast
Case: CiT Vantage White Gaming Case Black Interior 4 Fans HD Audio Card Reader
http://imgur.com/3ayaYr1
http://imgur.com/UbPMZMu
http://imgur.com/bwcwjJA
CPU: i5 4690K
GPU: GTX 970
