Hi all.
Today I decided to try cleaning out some dust from my pc. I used a dry/lightly damp cloth to clean off some surfaces and the fans. I also moved a few fan connectors around to see if I can get my chasis fans under control, since they are pretty loud. I tried to attach the cases fan controller to the moba and psu separately and at one point both of the chasis fans stopped working. I also tried attaching the 3 ping cpu fan to the controller. After my chasis fans stopped running both of my water cooler radiators started going to 1800+ rpm and I saw CPU temperature go up to 50 idle, bios once showed 90. I have everything back to my original wiring yet the fans dont work and the CPU feels very hot when touching the back.
CPU i7-6700k
Water cooler Corsair h105
Motherboard Asus z170 pro
Case NZXT Source 530
Im not sure if Ive broken the cpu coolers fan (i had the cpu fan not recognised error come up, fixed it by setting cpu fan speed to ignore) since I can hear water moving when I boot it up, yet less than normaly.
CPU i7-6700k
