[SOLVED] CPU overheating problem (89c°)
Jan 31, 2019
Hello, I have a problem with my AIO cooling, at least I think it has something to do with it....cuz I put new termal paste and my cpu temperature is still ridiculously high, can someone please help, if it means anything I have fx 8300 and I tried lowering base clock to 2.0 ghz
Jan 30, 2019
38
id say pump is bad or air flow is bad my last liquid cooling unit sprang a leek when temps got bad and had next to no cooling liquid left in it have you got the stock cooler still to test
Aint much to do, as was said before, either the mounting is wrong, the pump has stopped wich you can check the RPM, or the coolant leaked... OR you're running at some ridiculously high overvolt wich is a faaaar fecthed guess but hey... who knows.
