Hi I have an i920 1366 CPU.
It has a stock cooler and I've had no issues with it before.
For some unknown reason, it has started to shut down the PC.
When I check the temp all cores are showing 212C!! This appears to be the thermal shutdown point.
I have no idea why it has started to do this.
I've not overclocked the CPU, and it's running under minimal loads. i.e. Internet Explorer, Windows Media Player.
My case has two large 120mm fans and nothing has changed.
I can't see how I have picked up an airflow problem?
Surely the front fan should be drawing air in and the rear pulling it out.
Thanks
Thanks
