CPU Plug-In Problems
Slashbane
49
When I plug in my CPU using a 4 pin connector, my whole system will not turn on for some reason. If I unplug the CPU power supply the system will turn on. Anyone know a fix to this?
I have an intel CPU with an ASUS motherboard. It is also noted that if i unplug the CPU and turn the machine on nothing shows up on my monitor. Feel free to leave questions if you need anything cleared up.
Thanks
Slashbone, are you forcing in the wrong side of the 8 pin connector?
Tried almost everything except breadboarding, if nothing else works ill just pull everything out and do a bread board.
I don't think so...
